Results 1 to 1 of 1
  1. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I made a custom login screen for Linux Mint. It has Racing plane's prop with the Blue Angles in the background. Unpack. Go to Settings / Login Window. then simply drag the "SpeedPlane.tar.gz" into the Login Window list to install. Then select it from the list.
Name:	login screen.jpg
